1 - 9 of 9 Posts
ok so i was out riding on my 06 today all was well, then i stopped at the local auto store for some stuff. anyway i come back out to the bike and it wont start battery is dead, so i do the run and pop clutch method and i ride it for like an hour, went home and when i tried to start it, nothing. so i charged my batter for awhile on a charger, put it back on and presto bike was all good again, then later on same **** happened again. wtf! so when i did the pop the clutch method i was riding it home and my engine was bogging when i came to stop signs, and also my high beam lights barely worked and my display was on and off. this cant be a bad battery, what i think it could be the stator or the regulator. anyone who has had a similar problem please provide some input in what to do with out it costing me a arm and a leg. thx
why don't you think its the battery ? the battery is used for cranking the motor, and when the bike starts i believe the charging system kicks in... u can buy a battery tester @ a auto part place where u can put a load on the battery, or use a meter to test ur battery.. i would help u out but you fugggin far far away.. Goodluck bro
my first assumption was the battery, but after the bike starts you dont really use the battery right? i check it out on the weekend with my meter and hopefully its the battery
i would test the stator to start.
Sounds like the normal regulator problem to me. Just search " bike won't start when hot" and you'll get several threads talking about the same thing.
ok at the moment i am getting a load test done on the battery from the local bike shop here. so now can i assume if it passes the load test it can either be the regulator or stator?
alright load test done and they say the battery is toast. so new battery on the way! i hope i no more problems with this
so i put a new battery in, bike fired right up i go riding for a couple hours then hit the coffee shop to chat with a few buddies. i go to start my bike and guess what same crap again. definately not the battery, im thinking regulator now. and the stealership wants 200 for a new one and i dont know if i should buy used
1 - 9 of 9 Posts
