1 - 3 of 3 Posts
i took off all farings to paint and had to disconnect tach also , today i put everything back together i connected everything how it was and my bike wont start!? when i turn the key the lites turn on and dash too ,but push the star button and nothing ,anybody know what it could be ??????
i would double check your main harness connections and all the connections on the handle bar
Are you sure your battery is good? it could have enough juice to turn the lights on but not crank over the engine
also did you disconnect your kick stand switch at all?
i found the problem it was the tip over sensor., lol it was upside down , so all u people have the same problem check that , on the back of the sensor it says this side up, i didnt even notice it til now
1 - 3 of 3 Posts
