hey guys i need help..i just installed a set of new turn signals on my bike (rear) and they don't work, it said i didn't have to worry about polarity, but i tried starting the bike and it made a weird like electrical sound...any help would be appreciated
+ goes to +..... - goes to -
Remove the bulbs from the new signals, and check if the fronts still flash (it will be at a higher rate).
This will check to make sure that you havnt fried any of the turn signal relay system. If this still works fine, I suggest checking the bulbs that came with your new signals to make sure they are not a dead short (think I heard somone having this problem the other day).
Hope this helps.
Mad Chemist
emoreno said:
hey guys i need help.. it made a weird like electrical sound...any help would be appreciated
Hmmmm, Fuse go pop! You probably hooked the running light hot lead to the turn signal hot lead.
