Hi guys,
Is there anyone that has their PAIR covers lying around from an 03-06 and would be able to measure the diameter of the tube that comes off them?
I am planning to complete a starter valve sync soon and want to block these off with some caps as per the instructions in the manual.
By knowing the diameter of the pipe that needs sealing I can make sure I have the necessary caps available before starting the job.
No trouble my friend. Best wishes.
Managed to find appropriately sized caps which happened to be from some chair legs. :D
I was anxious about having to remove the airbox and all the associated gubbins to get to the PAIR system and block it off. Thankfully I managed to reach in from the holes where the intake tract passes through the frame and remove the pipes and cap them off from there. No disturbing the airbox was required!
Here is a quick comparison before and after tweaking the valves slightly.
Nice work man. And thank you for the detailed resolution post.
Sent from my XT1031 using Tapatalk
