1 - 8 of 8 Posts
So not sure whats wrong but today riding to work my HESD Light and the Engine Light came on and started flashing. Then it stopped!
About a 1/2 mile later it started again and the bike shut off.
What would this be? What could be wrong?
D
Put your kickstand down, bike in neutral, and turn the engine on. If a fault is present, a code will be flashed.
D
Diagnostic Trouble Codes. A little flash of the Fi or check engine light that tells you what's wrong with the bike.
D
Try this real quick.
1) Kickstand down
2) Bike in neutral
3) Hold throttle at WOT
4) Turn the ignition on
The HESD light should turn on and start flashing. Turn your bars back and forth and feel for a difference in damping. If there is no change or nothing happens (and test is done properly) there's an issue with the HESD unit. If it's fine, a wire was probably just moved around over a bump and shouldn't be anything to worry about unless it happens often and the lights stay on.
1 - 8 of 8 Posts
