Tonight I was adjusting the lights to make them even. Flipped the lights on and off a couple times to check. Now both of them do not work. Nothing was unplugged. I don't understand what happened. I was only adjusting one light to match the other. Neither one work now. Do you think it is possible to burn them out by just flipping them on 3 or 4 times?
check the headlights fuse ,the fuse box is behind the left side
middle fairing and if the fuse is burnt , change it with the same
number of amps
When testing the hids make sure the bike is running otherwise
you will kill the battery in a heart beat
If u got any question please post them and will try to
help you out , best of luck
Alright thanks moeman, You were correct. Checked the fuses, it was blown. I replaced it, and it works fine now. Thanks big relief!!
My pleasure bro :01_thumbu
