1 - 3 of 3 Posts
Hi I am currently installing a KT HID kit. We have connected all the wiring, the low and high beams work fine but the turn signals won’t blink. The turn signal is a constant orange light and not blinking. Anyone know what’s going on?
-Make sure your power/ grounds are correct!!!
How many wires do the turn signals have, 2??? 3??? Depending on type of turn signal, manufacture, etc, some will have a running light(solid) and the turn signal light(blinking) and obviously a ground(-) , some have just a ground(-) and turn sig light (blinking). Depending on what you have you might have wired into the running light.
You need a signal flasher relay. You don't have enough current to make the factory flasher flash so it just goes to amber. Let me know the year bike and I can get you a flasher relay. Thanks. T
1 - 3 of 3 Posts
