1 - 3 of 3 Posts
hey I gotta wierd problem, this only happened twice, I turned on my bike & took off & noticedmy lights wasn't on, so I turned on my high beam, the high beam came on but the low beam was off. then I started it up after turning it off & it came on again, wat could be wrong with the low beam?
Its normal for the low beam to come on even before you start
the engine and once you start the bike the light will shut off
then stay on steady when the engine is running
The high beam is different cause its controlled by a switch
regardless of the engine is running or not
Not a big deal... sometimes the aftermarket hid kits don't ignite properly when you turn the key.
Happened to me a couple of times too.
Nothing wrong/broken.
1 - 3 of 3 Posts
