1 - 20 of 22 Posts
I am having pretty much the same problem described in this thread:
http://www.600rr.net/vb/showthread.php?t=172799&highlight=high+beam
I am wondering where I can get the relay and how much it would be? Also the high beam didn't flicker on/off until after my battery died which tells me the battery dying had something to do with possibly killing my relay too... Just an FYI for others out there having the same issue.
You can get it from any dealer, you will find that the contact has burnt out.
Item number 9:
Ronayers Microfische
ooooo i should have read the thread first... i just figured you were talking about a delay relay:retard:
What contact?
The contacts are inside the relay, when they burn out they no longer conduct or may conduct intermittently causing the symptoms you described.
Inside a relay:
Also, I pointed out the wrong relay. Your after #8 here:
Its mounted between the headlights.
Discussion Starter #11
I swapped out a known good relay with the headlight relay and so far so good. Apparently the battery dying messes up this relay because it was fine before hand. So anyone out there having the same issue it is most likely your headlight relay.
A dead battery wont kill a relay, it was purely coincidence I think.
I managed to get the relay I needed for 7 bucks from my dealer so hopefully that cures this problem once and for all.
Discussion Starter #14
OK looks like the problem still exists even after replacing the relay and the battery. Anyone know of any other issues that could be causing this?
i was actually just reading this thread the other day for a tip on my issue- both of my headlights stopped working the other night.. was an interesting nerve racking ride.
anyways i thought the same thing yesterday and proceeded to dismantle the upper fairing for the first time. i bought a clymer manual with color wiring diagrams in the back and it was extremely useful. (with a multi meter) i traced the circuit and found a broken solder in the ignition switch module.
borrow a multi meter and buy a manual :)
Was that in an 07+? My low beam is just fine, its just the high beam that flickers SOMETIMES while turning it on or off... once its on it stays on... It is really odd.
Your issue isn't the start switch, if it was you would have lost high and low, I think you may have an issue in the harness or possibly the globe is dead, swap the globe and see if the problem moves, then after that find yourself a multimeter ($10) and we will have a look at the harness
Discussion Starter #20
What is the globe?
1 - 20 of 22 Posts
