So today I was riding and it started raining... Socked myself too... anyways, now I go out at night and see that the high beam is not on/working... What can it be? I know it had to something with the water... LMK, thanks
check the
1. Bulb
2. Black socket that holds the bulb ( shortens out )
3. wire connection
there is a relay that goes to the high beam...if it gets wet, it will short...check the relay as well...you can swap it with one of the relays on the left side of the tank just to see if it works....dont forget to put the relay back!!
