1 - 10 of 10 Posts
2003 Honda CBR600RR
When I'm going over 60 kmh and apply the front brakes the upper part of the bike shakes. Its almost as if something is lose. It seems to be coming from the part where the forks go into the frame, the steering stem.
Could it be the steering bearings are shot? How can I check it if they are. Anyone else ever had this problem.
Bike has 15 000 KM.
3 most likely causes. First, as already said, your rotors are warped. Second, your tire is old and is cupping. Third, your steering stem bearings are going bad.
Do you have a front stand? Get your front end off the ground and spin the tire. Do you notice the tire spins freely in part of the revolution but then really drags the brakes in another part of the rotation? Warped! You can also feel warped rotors when just braking slowly. I don't know how to quite explain it, but you can feel it in the handlebars and the brake lever.
Next, look at your tire. Spin it and run your hand lightly over the middle. Do you see or feel little bumps? When I say little they're usually about the size of a penny and will be separated evenly down the middle of the tire. Warped rotors will also make this happen even more, making your shaking even worse.
Lastly is your steering stem bearings. When they're really bad it's obvious. You can move the front end and feel the free play.
If his problem is the steering stem bearings...sure, that will help. But that's probably the least likely cause. There would be other issues than just braking. He may not notice them, but there would be other problems as well associated with loose steering stem bearings.
I would like to know this too, because my front end is coming off next week, and would like to replace this too because the bikes got 33k miles on her now, and would like to replace this as long as its apart.
what other problems are associated with bad/loose steering stem bearings?
Handling issues, tank slappers being the biggest! A steering damper will often cover up some of the issues caused by steering stem bearings going bad. If they are, you can lift the front end up (WITHOUT a stand) and hold the forks firmly. Shake them back and forth and you will feel the slack, often even hearing a "clicking" coming from the bearings. I always used a piece of wood and a jack under the headers to get the front end up for jobs like that. You need the front end to be under no load.
I have a scotts, so it might be covering up the problem. When I compress the front brakes when I am standing still, I feel a slight click when the forks come back up. I am assuming it is the bearing being loose?
shaking / stuttering bike
Hi all,
I seem to be having some issues as well.
When I brake (quite hard) at any speed above 20kph, the bike seems to go into ABS...
But I don't believe 2005 RR's have ABS right ?!?!
It's hard to describe the bike's behaviour but it feels like the wheels are stuttering over the tarmac, trying to regain grip 10 times per second or so.
The stuttering makes the entire bike 'vibrate' so hard, it sounds like you're shaking pebbles in the fairing.
like 'BRR BRR BRR BRR BRR'... as if you're riding over a road full of small stones.
Also, while this is happening, it doesn't really matter if you start braking 'harder'. It won't have any effect, and the bike simply stutters on. Quite scary because the brake-effect seems to be less.
btw; there is NO feedback on the brake-levers. So I'm not experiencing force feedback on the brakelever or paddle.
And now that I've experienced this like 3 times already, it's not that scary. The sound makes it awkward, the bike isn't sliding away or anything, it just goes straight on (not gonna try steering at that point ;-)).
I appreciate any insights or advice.
1 - 10 of 10 Posts
