I have a problem with my headlights turning on. I do not have anything wired to my low beams but I have the projector mod and hids wired to my high beam. The inline fuses for the hids are not burned out and if I turn the high beam switch on, the blue light on the cluster doesn't even turn on. Any ideas?
everything seems to be fine, unless I'm overlooking something. but ill check again later today
dude YOU BLEW A FUSE...LEFT HAND SIDE OF THE BIKE Mid Ferring....I THINK ITS A 20 AMP AND YOUR GOING TO NEED NEEDLE NOSEPLIERS....GOOD LUCK
the solder on one of the connections came loose. problem fixed.
Solder shouldn't be coming lose, maybe you should resolder all the connections to be safe it won't happen again?
I did, I just didn't do a very good job the first time I did it. I guess I just wanted to get it done at the time.
