1 - 2 of 2 Posts
Hello all. I'm having an issue with my 05 600RR that's driving me crazy. In neutral the bike revs sit about where they need to be. But when I put it in gear the revs jump up a bit. Only a little bit but enough to where I can definitely hear it.
Any ideas??
Thanks
I'm thinking a clutch/clutch switch issue? Not sure, do you get the same results if you shift into second or third? Do the RPMs change when you shift into second and third? If the bike runs fine until redline in all gears then I doubt it's the injectors.
1 - 2 of 2 Posts
