1 - 3 of 3 Posts
My name is peanut22 I have a problem and I really need ur help I have a Honda cbr600rr 2004 I went for a ride the other day and my bike went fine a week later I want to go for a ride and my bike wasn't priming so I went to buy a new relay for the fuel pump and my bike still won't prime so please help me all my fusesare fine and battery is still fine no problem by my kill switch because I can feel by the relay its working fine and I can feel all the relays are fine really need help!!!!!!
Are any lights dimming? Does it crank continuously or does it have a hard time cranking? My 04 sometimes wouldn't prime during winter days, summer days is great. Have you tried using contact cleaner on the fuel pump connector?
When you first turn the key to on and the engine run switch on, you should hear the fuel pump priming; if not, I would check the connections on the bank angle sensor and if those are secure, then ohm out the sensor to see if that is what's causing the issue.
1 - 3 of 3 Posts
