Is it more likely that my horn is shot or my horn switch? Cause right now my horn doesn't work and it's on an 06 600rr
Remove the connections on the horn itself and clean them.. If they get dirty will cause the horn to not work. T
if you're ever having trouble finding out whether the horn is shot, just get a voltmeter and test for voltage. if your horn is shot, most any 12 volt horn will work. most of them are just two connections for the positive and negative or ground wire.
