1 - 3 of 3 Posts
I tried searching but couldn't find this same issue. I took off my lowering fairings to install my frame sliders and when I took off the lower left side near the kickstand a small metal bracket fell out. I assume it was used to hold a small hose but I'm not sure how it goes back.
This is the hose near the kick stand.
This is the little bracket that fell off when I took the lower left fairing off.
there is 2 hoses one is a coolant vent and one is a gas tank vent, they just hang there behind the kick stand. You can bend that that piece you're pointing to back the other way to hold the 2 in place but be sure not to occlude them.
That pipe is the drain for the evap canister.. and the clip secures it to the fairing bolt that it is right next to.. But the clip should be behind the fairing.
1 - 3 of 3 Posts
