1 - 13 of 13 Posts
Im about 270 lbs. I have a 05 600rr (silver) feels ok when I ride alone,but when I add a 120lb. passenger it really squats, and will bottom out when I hit a bump, I have already adjusted the rear shock.I was thinking of trading in for a 1000rr next year, Do you guys think that would be better? will it handle more weight than the 600?
any info will help
thanks,
Overpaid South Pacific Barista overactive ADHD c
you can go up a bike forf sure , you could also put a stronger rear spring in, do a seach on rear springs there was a thread bout upgrading a while ago...
im running into the same prob im 275 and anything over 110 in the back it will bottom out. thinking bout doin the same but i was also thinking y do that get a rear shock and the hrc kit and the 600 will b just as good mabe better. right???
I would deff get a different shock, riding like that is 1. very bad for the bike, 2. You pretty much have no suspention.
you should be fine on the 600 if you get the suspension setup correctly. but look back in the owners manual there is a weight limit on the total load that should be carried. i think it's either 350 or 400. if it's 350 then you're putting more weight on the bike than it can handle obviously (with the passenger)
blackvomit said:
I beleive max load is 386 lbs, its actually on the sticker on the swing arm.
Stickers?......On the swingarm?......Hmmmmmmmmm....
I "liked" the sticker that said don't remove this sticker.......
Discussion Starter #11
tell me more
please tell me more about the rear shock and what I can do to make the 600 better for my weight, other than lose weight!!!
1 - 13 of 13 Posts
