hey guys i crashed in homsteady and i was wondering how can i check if the rotors are good while they are off the bike. thanks
the problem is that i got a new set (used) but i got them mixed up,lol. is there away to check them with out send them out. thanks
Do you have a table saw or some other perfectly level surface? If so, you might be able to lay them down and see if they are straight that way.
butt them up against the wall of the garage and the floor laying them flat on the floor, and make a mark where the top of the rotor surface hits the drywall/stud. then spin the rotor and see if it stays lined up. then put it on the bike and with the calipers still off, spin the rim to see if they are true.
may not be absolute precision, but it should work...
i don't know of anyway to check them off the bike . mount them on the wheel and install it , then use a dial indicator to check the runout .
