How many miles have some of you gotten out of your chains, either on your RR or another bike.
If you lube it and keep it properly adjusted no reason chain cant last at least 8,000 miles, though I would wager more like 13,000. However if you dont lube it and it either has to much slack or is to tight that will cut the life of the chain down real fast.
i had the chain on my previous f4i for 16,000 miles. i started lubing it at 3000 when i found out.. ahhahaha.. It did have a lot of slack in it.
About how much slack do I need to keep in the chain, and how much does a replacement usually cost?
