1 - 12 of 12 Posts
thanks jason. i checked ronayers, but the 600rr is not even in their inventory. i checked the f4i and 954 and found them to be around $100. would the RR's cover new be around the same?
ragamuffin, you can give them a call. Also sevicehonda. Ronayars web site is often behind their inventory. This is a good thing in that if you see it on their site, they almost always have. Nothing is listed too soon
if you want any parts from ronayers you have to look at the microfiche for the 600rr then there is an option on the side to add to cart where the price will be listed :bitchslap:
YellowRR said:
Take that money and get a better case then, like one from Billet Tech
Next time if you go down it wont crack again.
it didn't crack...just got scraped up. and it's the right side, not left, in which case billet tech makes only the bolt-on cover for the timing cap area. but thanks for the suggestion. i had considered it, but i have to make a number of repairs, so i'll do that later if ever.
L
just pop that bad boy off, sand it, and then paint it black. should save you some money.
1 - 12 of 12 Posts
