grinding/filing pins off is possible.
but there is not much range of adjustment even so.
Woodcraft has good clip ons that let you get more room and range of adjustment than stock,lighter too.
they give me a wider more forward stance on bike and knees and elbows do not interfere nearly as much.
As has already been stated, the stockers have very little adjustment, although there is a little.
1. Turn the bars all the way left and take a measurement from the end of the bars to the side of the tank. Turn the bars all the way to the right and take the same measurement. Loosen one or the other and try to get the same measurement on both sides. If that is not possible, you may have something bent..........one or the other of your clipons.
