1 - 2 of 2 Posts
Here are the two sides:
Right Side:
Remove the axle nut, it helps if you loosen the two bolts on the side as well.
Place the axle slider in, and then re-tighten everything.
Put the outer puck on, and then put the pin in. The side of the puck with the dot is where the end of the pin goes.
Left Side:
Loosen the allen bolt, place it in the axle and then tighten the allen bolt:
Place the puck over the top and put the pin in. The side of the puck with the dot is where the end of the pin goes.
1 - 2 of 2 Posts
