2010 engine blew at the track last weekend and I'm trying to drop it out now.
Are there any type of write ups or tips here that may help?
Pretty much just remove everything surrounding/bolted to the engine. Then, if it's anything like my f2, you can support the engine from underneath with a jack and just let her down with the help of a friend.
My tip would be to buy the clymers manual. The one I had for my f2 was awesome.
I replaced the motor in my '07 about 6 months ago. I just followed the steps in the service manual, I'm sure there's a copy floating around on the forum somewhere.
You'll need a jack to drop the motor (bring a friend for that part too), as well as a special socket for removing the castle nuts on the frame bolts. I bought the one in the link below, the exact one is unavailable but there should be similar ones on amazon.
https://www.amazon.com/gp/product/B019T7C4FS/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
Good luck! Post up if you run into any snags.
