You flip the shift linkage on the transmission 180. There is this hose on the left and the hose that is right up close to the shift rod. Take 3 zip ties. Put one on the left hand hose, one on the right hand hose, and one that goes through them tighten them up untill you have just enough room for the rod. It is only 1/4-1/2 inch but I have had the shift pattern like that for the last 3 months and 2000 miles and it will not rub. It can be done. You will be very pleased with the results when you do . Good luck :mrgreen: 8)
