Resident Leg-Humper Females Beware
i have that same diagram, unfortunately, it doesn specify which line is the running light. just wire up your new signals and test them. the turn signal should be brighter than the running light, if it ain't, switch ya wiring around.
it's so easy if you look at both sides....green ( ground ) , orange (on one side ) , lite blue ( on the other ) , which leaves only one other wire that is common to both side and is powered ..... the one with the tracer . hope it helps ! :D
check my short stalk thread in the mods section, i had the same problem and i figured it out, unfortunately i cant remember off the top of my head, but just look in the thread
