Hey guys, I went out and bought some honda cleaner this stuff is awsome. Works on every surface, my bike looks sweet. BUT, I accadently sprayed the stuff on my tires not the whole thing but the sides and stuff. Is this stuff the same as Tire Wet. My tire is not oily but im really skepticle about riding. What do you think.
bennyboi said:
no biggy, just ride easy and scrub it off.
I agree. If it's really bad take some fine grit sandpaper and scuff the tires. It should wear off pretty quick. Just don't go hitting hard twisties until they're good and scuffed again.
Tim
blueaudi, just make sure to take it really really easy after you clean your tire to make sure the back end isn't squirrly in the twisties.
I said "scuff it off" one time on here and people said what an a$$hole I was.
I think as long as you do a little side to side and progressively lean further you will be fine. You will always have a contact patch which is at least 1/2 clean.
