1 - 14 of 14 Posts
Well I was out a performance shop today a really good friend. He said that the idle of my bike seemed high. It idles right at 1500 is that normal? He thinks that it should be lower. Reason he said that is because that is make a hell of a chunk in to first gear.
Any ideas guys
1500 - 1300 is typical
07/08/09 RR all idle at 1500 and no you can not adjust the idle its controlled by the ECU
THE 03 TO 06 RR have an idle adjuster that you can use to adjust the idle
Yep normal,your bud is mistaken
My 03 RR had a perfect idle at 1200 RPM its best to set it up after the bike warms up not before
so it would be an accurate adjustment
1 - 14 of 14 Posts
