I have read previous threads and 1300-1400 rpms seams to be normal idle my bike idled kind of low about 700 rpms so I changed my idle higher. But that's not the real prob before and even after I adjusted the idle the rpm gauge would flutter 200-350 rpm less with it idled up but I don't want to cover up the problem what do you think it could be?
I have no idea what you just tried to say...
What year bike do you have?
Can you try describing your problem again? I think you said that the idle was low, and you adjusted it but not to the correct rpm as you didn't want to cover up a problem?
Well mate, your idle needs to be set at 1300rpm +/-100rpm. Your problem was that your idle was set to low. Your bike is fine, nothing wrong with it.
