So, I parked the bike for a moment the other day and tried starting it up.
The start button itself just wasn't working - bike was in neutral, kick stand was up, engine kill was off, but no signal from the switch was getting through.
I managed to get it to turn over after a while by only lightly depressing the button and finding a sweet spot that gave it a good enough connection to turn the bike over.
Anyway, I'm curious to know if anyone has encountered this before.
I'm considering peeling the switch apart and making sure the contacts aren't dirty/corroded or maybe there's a loose wire I can fix.
Advice?
D
It's not really a common issue, but Honda's start button/kill switch assemblies have been known to go bad. You're might be on the way out, but since you can get it to somewhat work, might just be a loose wire.
