I put in this indicater today. It is a datatool digital indicater and the install went very smooth. I only had to take the plastic piece off that goes between the gas tank and the front fairing. The one that is on the top, right ubder the handlebar. Once this is off there is a blue wire connector that can be taken apart to remove the front upper fairing and all the wires are in that bunch. I spliced in on the bike side of that blue connector so that I can remove the upper fairing without any trouble. The indicater is on the dashboard, which stays when the upper fairing is removed. The wire connections are as follows.
INDICATER BIKE
black-------------ground----------green
red---------------power-----------white/green
yellow------------tach-------------yellow/green
green------------speedo----------pink/green
brown------------neutral----------lt green/red
orange stays open for learning
The set up was very easy and goes pretty quik with the bike on the rear stand. Over all am very happy with the investment and instalation. I hope this helps somebody.
