Installing new engine and clutch casing..
599 Views 4 Replies 2 Participants Last post by  SJPericak
Well I was taking off my old engine and clutch casing because the owner before me laid it down and it got a decent amount of rash so I decided to replace the casing. When I took the casing off the I believe the thrust washer? Well anyway the picture speaks for itself..Im not sure if the one washer it suppose to be bent the way it is I figured you guys could give me some insight. If it isnt its due to be replaced as well lol. Thanks ahead of time
Dont worry, that washer is suppose to be like that.
Thanks man, do you know in which order it fits in the entire setup once installed back?
No problem. The gear goes in first, then the wave looking washer and last is the normal washer.
You can check out the diagram on ronayers if you are still not sure.
http://www.ronayers.com/Fiche/TypeI...CBR600RR/GroupID/416503/Group/STARTING_CLUTCH
Thanks man I really appreciate it a bunch the bolt and washer fell off before I could take a look when I removed the old casing.
