2003 CBR600RR While riding, red MIL light comes on with FI indicator, will go off then on again with bike cutting out and on repeatedly. Does not flash any codes either by kick stand down or manually shorting plug methods. Could it be the fuel pump going out but not completely gone? I've checked connections and battery is good. Trying to get home for the holiday but it doesn't look good for the home team. I've also checked bank angle sensor, fuel pump relay and engine shutoff relay.
Any suggestions?
Thanks in advance for any input.
Cheers!
Check your battery connections and grounds if you haven't yet. Doesn't sound like a fuel pump problem.
Do the lights do the exact same thing as they would when you first turn the key on?
If so you should look for loose connections in the main grounds, Main power leads, and wiring to the ignition cylinder.
Sorry about the late update to who ever may look this up. It was the red stop button located on the right hand control. No rhythm or reason, accidentally discovered it and was able to reproduce the symptom occasionally. Decided to replace and issue was resolved.
