Very sporadically lately, sometimes i will upshift (GP shift), and the lever will just stay down for like a second longer than it normally does (normally it returns immediately). when it does finally return back, it does so in a timely fashion. I am not getting any false neutrals or anything like that.
i'm thinking it may be the shift return spring on the pawl behind the clutch basket, but then if the spring had failed why would it be so intermittent? and then why would it ultimately return in a normal fashion without me having to pull back up on it? any ideas?
thanks ahead of time!
bump. anyone have this prob. before and if so, what was the culprit?
I know that you can assume as much as I can about the problem. My guess is the return spring. I have an '06 motor that I'm wanting to part out. I can pull the gearshift spindle and spring. Only bad part about replacing these is that you have to pull out the clutch basket to get to it. Let me know what you think.
