Is it reusable?
446 Views 7 Replies 7 Participants Last post by  NewRedRider
Eye Water Automotive tire Wood Automotive wheel system
deep 0.07inch~0.1 inch i guess.............
I don't know why, but the piston broke and the pieces dug up the wall.
ugh... danoxyz.. thats why....
1 - 8 of 8 Posts
Sorry to see, pretty sure that is a terminated bore/block.
Reactions: 1
What happened?
i dunno, surely previous owner lmao
I decided to work on the cylinder sleeve.
I'll reveal the before and after later. :DD
Reactions: 1
3
I just went through this, melted a hole in a piston and scored the cylinder wall...
My original plan was to hone the cylinder smooth or bore it .5 over and get a 67.5mm piston...
But then I found out about these coated cylinder walls and realized that honing or boring wasn't really the best option.
I ended up buying a used case ($150) & a used piston ($30) on ebay.
Plus new rod bolts ($55) & a couple gaskets and rebuilt the whole thing for about $400 myself if you have the time and patience 👍
The bottom case is the old one and the 2nd hole from the left was the one I honed before I changed my mind
Reactions: 5
How did hole in piston develop?
Running too lean.
IIRC, Bad fuel pump/loss of fuel pressure and flow.
Reactions: 2
1 - 8 of 8 Posts
