1 - 2 of 2 Posts
Ok so this is kinda a long story.
I been restoring this 2005 cbr600rr to track ready condition after it's been sitting for years.
I had a bad PC3 and fuel pump and few other issues all sorted now, but after sending it to someone else to get the valve clearances checked and check over they told me that there is something wrong with the fueling and was severely lacking power above 10k rpm
At the time I thought this was the kinda broken TPS connector clip which I wasn't bothered about at all because I had bought a replacement pc3 and knew the connector clicked into that fine.
Anyway turns out the pc3 didn't fix it and the problem is still there.
So the mechanic's advice was to look at the TPS since the TPS bolts had shown evidence of being tampered with. However I measured the TPS voltage and it was within range of normal, but I found a good deal on a used throttle body so I jumped on it.
So I have now fitted the replacement throttle body with stock set TPS.
Unfortunately I had to use tie downs from a ladder to remove the throttle bodies as they were stuck so hard and in the process I busted the thermostat cap hose pipe.
So I got a replacement thermostat cap fitted it and got a carb tune tool for syncing the starter valves on the new throttle body as I accidentally moved them while cleaning and figured it was a good thing to do anyway.
Made a thread here because I wasn't quite sure about blocking off the pair valves
http://www.600rr.net/vb/35-maintenance/568786-starter-valve-sync-noob-questions.html
Upon plugging in the carb sync gauges I noticed I get no pressure at all on cyclinder 4
So I ripped off the airbox again and cleaned the throttle body again and this time visually adjusted the valve on the 4th cylinder as it looked to be all the way closed.
Tested again, same problem.
Also noticed the bike is leaking quite a lot of coolant/water (I put water in it because I am draining often)
I am yet to work out where the water is leaking from, doesn't appear to be the thermostat that looks fine.
So could it be I have no pressure in cylinder 4 because cylinder 4 isn't working at all?
Was this my problem all along?
I guess the next step is to start checking the voltage on my injector connectors.
So I don't think it is missing a cylinder, I did some testing
So I think I will just forget about the starter valve/throttle body sync for now as nobody seems to be able to offer much information on it.
1 - 2 of 2 Posts
