Post Whore Extraordinaire
I'm guessing you bike keeps dieing and its not charging?
It may not be your battery.
You need to get a voltmeter, put it on the terminals at idle, shouldn't be less than 12v.
Then rev it up to about 5k rpm and hold. If the voltage is less than 13v its not your battery, its your charging system.
Here's the trick. You can buy a used rectifier/regulator on ebay and try that. If it works then good, if not its your stator, and those are more expensive.
If you go on 1000rr.net you can read up about the stator issue with those bikes. You can read about all the symptoms. Like fluttering instument panel, sputtering, spikey acceleration and all that. I just changed mine like a month or so ago.
