judder washer goes in first, then the judder spring. as you look into the clutch the spring should appear concave to your view (with the OD of the spring working against the next plate you put in)
this is in agreement with the manual that says the convex side faces the spring seat (judder washer)
thanks! So basically the orientation with the convex facing the seat spring( top picture example is correct)
the middle of your 3 pictures shows how you will install it into the clutch. with the convex facing inwards.
