My battery is holding a charge but the CCA are low (90). So the battery is showing a voltage of right around 12 but the CCA's are far below the 190 that the battery specs show. I have one on order but was wondering if it would be safe to try to jump start it with a car.
K
sure. the car doesn't need to be started though. have you charged the battery before you tested it? 12VDC is too low. what prompted you to get a new battery or start the thread? Are you haveing electrical problems?
recently bought an 04 and it isn't starting. The the starter just clicks. Had the battery tested and those are the readings I was given. 12V and 90 CCA. It seems as though it is the original Yuasa battery. The specs on the battery say it should be 12V 190 CCA when new.
I was having an electrical problem with the rear turn signals but I rewired them and they seem fine now. The bike powers up and I checked the horn and signals and the fuse didn't blow. The bike just doesn't turn over.
K
did you charge the battery prior to load testing it?
you have an 04, your Regulator/Rectifier is suspect already... your new battery will not last long if the R/R is malfunctioning.
No I didn't but when I asked the shop about that they said that the battery is charged. He said 12 Volts is charged. He said there is probably a bad cell causing the weak CCA's. Does that sound right? This is the same shop that then tried to sell me the battery for $175.
1. Would charging the battery improve the CCA's?
2. Does the R/R act as an alternator does on an auto?
Read a bit about the R/R problems and will go ahead and address that as soon as possible. Should it be replaced or moved? I read a couple of remedies on here.
Thanks for the responses. I am just learning about these things but want to learn more.
K
BUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUULL SHIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIT!!!!
Charged is somewhere in the neighborhood of 13.x volts! man oh man, the economy isn't THAT bad... no wonder everyone want to buy online when the dealership is fuking you that badly... wow!
Abso-friggin-lutely.
Without getting too technical, yes.
Well, first of all we need to test it. yes the first design was bad and it should be replaced, but to teach a lesson, go ahead and test it. what you do is take a base reading of the battery. then start the engine. put a volt meter to the battery and take note of the voltage. It should be above 13 volts. then take note of the voltage with the high beam on and the rpms at 5000. it should rise significantly, but stay below 15.5 Volts. if it does not (and i suspect that it wont) the R/R is faulty and must be replaced with a 2nd generation Reg/Rect. module and bracket.
you're welcome. i'm here to help and educate.
Thanks for your time Knight! I really appreciate it.
******** is exactly what I said when he told me the price of the battery. Luckily I found this forum and was able to find a battery for $55. I am going to run those tests and see what is going on with the R/R. Hopefully nothing.
Thanks again.
