I have put track plastics on and can't find a way to mount the bas. I figure I will just get rid of it. How do you do this? Cut off the connector and then connect two of the wires?
Leave it attached man i know its a track beast and all but you do want the Bas
to do its job and cut the fuel off the fuel pump & kill the motor in case God forbid
you go down having a spinning wheel & chain while on the ground is dangerous
Use tapper screws or drill holes in the fairing stay and nut/bolt in place. If you look at the front of the stay you will see 2 flat spots that line up exactly with the bas holes on the sides. T
I tried putting it there tripage but it hits upper cowl. I will try agin though. I would like to keep it I never though of it as dangerous
+1 on what Moeman said........Find a place to mount and keep it in the circuit.....even if you have to make your own bracket and put it somewhere.
