Well here is some info on my bike its a 2008 600RR with 4k miles.
PCV installed
BMC Filter
leovince SBK slip on
Hids and some Intigrated Tails
About a week ago the bike started to jump and run like **** after it got warm. The bike starts fine and runs flawless until it get to operating temp and the fans kick in. It seems to start when the fans kick in and keeps happening until they turn off.
The power commander is installed correctly and everything is plugged in. The only test i have done was hook up the PCV to my computer while the bike is running and it seems to have NO problems.
Could this be a Power commander issue?
Battery Issue?
Coolant Issue?
Sensor Issue?
I have not checked any codes.
I always use 93 Octane gas.
Any help would be much appreciated! Thanks Guys!
The 93 Octane is not necessary... anyhow.
The jumpiness can be caused by the mods you have. A simple tune will get it back in working condition.
You have so much installed that it far from stock therefore it needs to be adjusted.
