1 - 9 of 9 Posts
Hey guys, sorry for two dumb question threads in a week but not even sure how to properly search this question.
So I have driven manual cars for years / drag raced at tracks etc.... Anyways my question is this is sporadic and doesn't always happen but shifting up I sometimes have to lift twice to get it to engage the next gear. I've noticed if I press up on the gear selector without pulling the clutch it will 'prime' (probably a horrible choice of word for this) it for the next gear. Meaning I'm in 3rd wanting to go into 4th if I lift up on the gear selector I can actually move it up without shifting but then to shift I pull the clutch and press up again. (First time there's movement to actually push up but if I tried to press up again its solid and can't)..
So I've tried playing with how much I pull the clutch lever and press up.. different rpms etc.. Anyways sorry if this is a stupid question, but hopefully its better than a CeeBee question.
What ur doing is called preloading to shift. And u can actually shift wo using the clutch. Its a little rougher n not sure how good it is for the tranny. But u shouldn't be having a difficult time shifting if ur pulling in the clutch.
Oh well **** at least I know one more thing then!
So yeah when I pull the shift lever in and push up 50/50 i'm pushing up in air and have to push up a second time to select the gear...
Theres always a lil bit of play in the lever but u shouldn't have that issue in every gear. 1st to 2nd is usually the only time u gotta try a lil harder due to shifting past neutral
shifting
I find a fresh oil change really makes shifting smoother and silky, however I find that if you are not precise with your toe upward movement it does tend to stick once in awhile.
Thanks guys, I'll continue to play with it and see what -I'M- doing wrong as its most likely newbie error vs something on the bike :) I def appreciate the helpful responses!
1 - 9 of 9 Posts
