will this cause the front tire to have like a flat spot? after driving it after a month, i hear like a wobbling sound. will more air in the front tire likely solve this? thanks.
Yeah, just check your pressure... it should go away after a couple days of riding
Like everyone said , correct tire pressure and a few heat cycles should even out a flat spot if the bikes been sitting . But if you do have a flat spot you should feel it more than hear it . Do you notice any chatter in the front end or just a strange noise ?
one thing that you should be more concerned about is if the front tire was on concret. i've heard that having the rubber in contact with the concret for an extended period of time will cause the rubber to harden and fatigue sooner.
if i were you i'd mark the sidewall with a grease pencil and keep an eye on that spot.
