Kimchi Rider's Fuel Tank rust removal
154 Views 4 Replies 2 Participants Last post by  NewRedRider
2
The corrosion inside the fuel tank is severe, so I would like to restore it using citric acid. Once the corrosion is removed, I will use "tank sealer" to coat the inside.
  • Helpful
Reactions: 2
This is why I try to keep my tank FULL. I've already been down this road and it's not fun. I'm curious to see how yours comes out with using citric acid and the sealer because I need to redo mine at some point. Post up a good "How To" and I'll separate this out to a new thread. This is a common problem.
6
BEFORE
AFTER
This is a 48-hour review of citric acid.
The fuel pump is less effective because of the gasket, but the same effect is expected if the gasket is removed and only the fuel pump is submerged separately.
The tank sealer is not yet in use.
I'm not promoting a specific product, so don't misunderstand the intention. I recommend the product with the best reviews.
How to remove rust in fuel tank?
step 1.
Fill the container with 5 gallons of water.
step 2.
Mix 4 pounds of citric acid in water.
step 3.
Empty the fuel tank. It doesn't matter if there's a small amount of gasoline left.
step 4.
Fill the fuel tank with citric acid mixed water and seal it and wait more than 24h.
(In my case, I sealed the bottom with a fuel pump. It's also possible with duck tape.)
(The water was leaking out little by little, so I turned the tank upside down for 24 hours.)
step 5.
Dry it well and coat the inside of the fuel tank with a coating chemical.
The process is over when the coating chemical dries well.
Reactions: 1
step 1.
step 2.
step 3.
step 4.
step 5.
No worries Kimchi. Your corrosion is much worse than mine was and your method of using citric acid did a much better job then using vinegar. DO NOT use vinegar. I went through the same method of filling the tank and letting it set for a day or so. Only to find out that the vinegar had dissolved the tanks fill cap locking mechanism, the fuel cap had popped open, and rain water had got inside the tank. What a mess! I had to replace my fuel cap with a race cap and I was never able to get the remaining rust out. Every time I tried to get the last bit of rust using the vinegar the surface rust formed as soon as I was finished and it dried. I finally gave up.
  • Love
Reactions: 2
