Yup, definitely pressed in too much and causing binding of link.
Yup, definitely pressed in too much and causing binding of link.Hello,
Manages to take some measurements.
Original factory link = 20mm
My pressed master link:
Middle 19.5mm
End: 19mm
The master link is 1mm more pressed than the factory links. Is this too much of a difference?
Hi Cannon,Your front sprocket turns your transmission so some noise and a little free play is normal.
Have you already checked your cush drive (rubber bushings) in your rear wheel for deformation also? Those rubbers shouldn't make a difference when spinning on the stand by may be apparent when you ride the bike.
