1 - 13 of 13 Posts
I had to cut my trackday short when I started hearing a knocking/fluttering sound coming from my engine and once i pulled off the track the temp was at 244.. Someone told me that I could've blown a valve, which I doubt.
So a couple days later (today), I start it up, and I still hear the fluttering sound whenever I give it throttle. Its not very loud, but definitely noticeable especially above 4k. Also, my temps seem to be climbing much faster, but I didnt let it get above 223 tonight. Any ideas on what this could be? Could it be a buster water pump or is it something much worse? Any tips greatly appreciated before I start tearing into the bike..
Can you post a vid so we can hear exactly what it sounds like?
sorry no camera.. ill try to record it with my phone maybe or laptop. I think I may take it to a shop sometime this week and let them check it out
Took the clutch cover off today to check for anything out of place or loose but couldnt find it. Also, I found out that as the longer I ride and the hotter it gets, the noise gets more obvious. Also, after a certain amount of time riding, it really doesn't want to cool down - i.e. the temps just start climbing leading to overheat. The fan kicks on, but doesn't really do much.
Would a faulty CCT do this? Could it be a busted water pump? Any advice appreciated before I take it to the stealer. Oh and the bike only has 4500 miles on it with 2 trackdays.
It doesn't seem to come from the water pump side though. Oh well, I did something I promised myself I would never do and took it to the $90/hr stealer. F**k it. They're gonna diagnose it first so hopefully after that I can take over. I'll keep you guys updated for future reference.
little update
Okay, this is weird. I just called the dealer and basically it came down to changing my oil or going in to replace rods or something else (20-22hrs at $90/hr - HA!) I'll do an oil change, but I dont see how the oil deteriorated after 2 track days and a few hundred miles or regular riding. It was the good Repsol race oil as well.. Synthetic oil shouldn't just go bad so quickly - or can it?
If it was really the rods - would those be RPM-dependent? The noise from my bike IS RPM-dependent and the warmer the bike, the worse the noise. Ill keep you posted. I may possibly need to buy an engine from one of you here soon! :tard:
maybe your thermostat isn't opening ? (you need a new t-stat). rods? what kind of rods? i highly doubt your synthetic oil took a dump so fast, although the high temps could've killed it much faster so it is a possibility and if I was you, i'd certainly change it. it is not the ROOT of the problem though, just an after-effect. were you running water wetter? 50/50 or what?
how many miles on the bike? cam chain could've skipped a tooth and thrown the timing off, making the spark plugs overheat and fail, injectors/coils could be faulty causing overheating, many things could be wrong. is it throwing a code?
Discussion Starter #11
I havent gotten around to the bike yet as I've had a million other things to do and work, but it only has 4500 miles, i ran regular 50/50 coolant in it.
If it skipped a tooth - would that lead to permanent damage? I am guessing that could be related to the CCT as well.
Like I mentioned before though - at idle there is no noise. Not until about 3k rpms. Ill be posting updates once I dig into it again. Thanks for all the replies and help so far
Try this - take the fairings off (if not off already) open the cap on the radiator and blip the throttle - if fluid doesn't come (just about) flying out I'd be betting the water pump gave up the ghost.
Well, my engine is toast. Basically I've got valve leakage and scoring on the piston (s). So yeah people change your old coolant to prevent overheating! I learned it the hard way... Now I've got to find a new motor before Laguna in Nov.
1 - 13 of 13 Posts
