1 - 16 of 16 Posts
When i first lean the bike on the kick stand i dont see any drips, but the following day i see a drip line (dark) running down the lower fairing. Should i really worry abut this? Anyone with feedback? thanks.
First, welcome to the boards jaimito. Next, from how high up does the drip start? Is it just on the fairing lower or is it on the mid fairing? Has the bile had an oil change recently?
L
like mtc was hinting, if you changed your oil the drain bolt has to be torqued down to the correct ft/lbs or it will drip.
you really need to try to see where it is coming from .. could be oil that was not cleaned up from an oil change.. so take those lowers off and take a look
Mad Chemist
If I over lube the chain, I get a lot of crap running down the kickstand there and the lower fairing. If it's thick and sticky, that's probably what it is.
well, it shouldn`t be hard to tell if its from the drain plug, just take a look at the plug and see if its wet. Its prob what WherzRoony said, coming from the chain.
C
I have a leak from the top of my radiator. Where the hose comes in. It only drips when I lean it on the kickstand. I've tried to tighten the hose clamp but it still get drips. It will drip down the side of my middle faring. Anyone else experiencing this?
I think maybe that is what i am trying to describe.... right behind the front will on the lowest part of the plastic is where these drips are appearing...sorry if my terminology was incorrect.
C
put something under it to dee if the drips are green... Also the hose clamp is easy to get to if you want to try to tighten it...
If its dark its either from the oil drain plug or the oil filter. Are the drips inside the opening behind the wheel? I`m betting oil filter here, make sure its hand tight.
yes right behind the front wheel on the lower part of the fairingin front of the radiator.... Thanks ill check te oil filter out.
1 - 16 of 16 Posts
