1 - 20 of 50 Posts
Well my bike won't start :/. I left her sitting in my garage for a week(it was 10-25degrees all week).... went to ride her yesterday and she wouldn't turn on. Lights/gauges are all working perfectly when I turn the key, and it sounds like it's about to start... but it just won't. Tried push starting and then jumping it... neither worked so I'm assuming it's not the battery. Could it be possible the fuel line or something is frozen from the cold weather? It ran perfectly a week ago. Supposed to get up to 38 today so I'd love to figure this issue out and go riding.
You can jump it from a car battery if the car is not running, or you can go out and get a Battery Tender Jr and hook it up to re-charge it.
Even if the battery is toast you will have the Tender for the winter. It is a good idea to have it hooked up anytime you will not be riding or the temperature is going to be low for an extended period.
It's just a completely dead battery. END THREAD lol
That's what I figured, but I tried jumping it with my car while turned off... and also tried doing a push start. Neither worked.
Thanks man, I actually tried to jump it with my car while it wasn't running, but that didn't work. I'll definitely get a battery tender for here on out. Now to just figure out why it won't run :/ I also think it has to be the battery, but I don't get why jumping it or push starting it didn't work. blahhh
Do you smell gasoline at the exhaust? You may have flooded the engine during your starting attempts. Try jumping it from a car battery again, but this time hold the throttle wide open while you crank it for 10 or 15 seconds. This might clear out the excess gas and allow it to start.
Thanks alot man, I actually did smell gasoline towards the end of trying yesterday. I just did as you suggested, took like 45 seconds with throttle but it started up. Thanks alot for the help guys!
Alot of these issues could be solved if people were to go out and purchase a 30 dollar multimeter and see if youre getting 12.5v -12.7v out of the battery. Or to test continuity and fuses. :shakehand
ive got this battery tender from harbor freight, 10 bucks and it works great.
http://www.harborfreight.com/automatic-battery-float-charger-42292.html
Awesome, just ordered one. Thanks man. And yea, I'll admit I wasn't prepared to leave it sitting for a week. I'm heading down to Oklahoma in the first of January so I didn't winterize it. I actually go to school in the south so I can ride the bike and drive my TT'd 350z all year long. Haha
why does everyone say not to run the car while jumping the bike....I just don't get it. Make sure you don't use your run switch to turn off the bike, even though it's the same circuit as the ignition key
Your car battery is 12.6 volts, but when the vehicle is running it jumps to 14.4 because the alternator is charging the car and running the accessories. This is too much voltage for the motorcycle battery.
Actually make sure you DO. Its a great habbit to get into, using your thumb to kill the bike then turning the key off. Any excuse of I always forget and I leave my key on or forget to turn the switch back to RUN is a lousy excuse for being lazy. Its some things like this that should become second nature so if you would need to quickly kill the bike, you don't have to remove either hand from the grips.
Have jumped my bike with my diesel truck on and off. Never had a problem.
The reason you don't want to use the kill switch is because on these bikes the switch is a piece of rubbish that is prone to failure. Don't use it and there is no arcing across the contacts and it doesn't get the chance to wear out.
No offence but your wrong... right idea wrong reason.
The reason is simple, even though a cars electrical system is very similar to a bikes and the voltages are the same (13.2V no load battery and 14.4V charging) the current capacities are wildly different.
A bikes battery is rated at anywhere from 80CCA to 140CCA, a cars battery could be anywhere between 150CCA and 600CCA. Trucks can be anywhere up to 2000CCA.
This is what causes the issues, the starter motor pulls a certain amount of current from the battery and as a result there is a certain voltage drop across the wiring and the output voltage of the battery will drop a little as well. The starter motor is designed to work with this occurring and spin at the correct RPM. So when you add up all the losses in a system that is operating correctly you will find that the starter only gets ~9V - 10V while cranking.
When you throw a car battery in the mix and crank the bike over you have voltage losses across the jumper cables and in particular the clips where they attach, with the car off and floating at around 12V this is enough to bring the voltage down to a respectable level for the starter motor and no damage will occur.
If the car is running you have a 150+CCA battery and a 100Amp alternator operating at 14.4V the current potential in the system is so high that the load of a bikes starter motor is no where near enough to drag it down and even once you add in the losses from the jumper cables and what not you still get around 12V at the starter motor, which will make it turn over to fast and put to much current through it.
By placing to much current through the starter motor you risk damaging the windings and more likely the brushes.
Hope that helps Doof, and Mattieg now you see that its not the battery you should be worried about cause even at 14.4V it's still well within its normal operating parameters, its the starter motor.
with that said the starter can only "pull" what it can "take". I can't count how many times I've jumped my battery from my truck with 2 deep cycle 980cca. Still have the stock 03 starter. So make sure to keep a dead battery in the bike so you don't hurt your starter? We have seen bikes (R6) running almost 15 volts while running...The starter is the least of concern.
The starter is all your concerned about when jumping the bike, and yes even though the starter will only draw the amount of current that is proportional to its resistance and the applied voltage. The issue is when the applied voltage increases so does the current in the starter.
When starting of the bikes battery you can only draw a relatively small amount before its output voltage starts dropping, when connected to a running car there is no drop and the applied voltage at the starter motor increases thereby increasing the current it draws ( I = V/R).
Also, this is only relevant while you have the start button pushed... paralleling a running car to a bike whether running or not is no issue, just starting it is.
Good to know about jumping with the truck off. I had jump my bike twice this past weekend and did it with the truck on. Hope I didn't cause any damage.
Not likely to cause damage when you only do it once or twice, its when you do it repeatedly or leave the starter turning for an extended period (20 seconds or so) that you will run into trouble
hmm thats odd, i've got 38k miles on my rr and have used it from day one with not one issue. I just see it as something you should know to use quickly and effecicently just like brakes or anything else the bike is equipped with. If something wears out from use, replace it. Its like saying i'm not going to use my High/Low switch b/c when it wears out I don't want to replace it.
I'm sure there are switches out there that are bunk and there are hundreds of things that play a role in why they wear out prematurely; weather, moisture, how the bike is maintained etc. I just have not had any runins with anyone I ride with having an issue with one (3 RRs and some other bikes).
Anyhow, use it or not. Everyone has an opinion and a perception, and is entitled to it.
I don't want to start a pissing match but do you have any data on the starter? Or just a guess that it can't handle 14vdc...just trying to stop internet myth monsters.
1 - 20 of 50 Posts
