1 - 17 of 17 Posts
I recently bled my rear brakes. I was using the Honda DOT 4 brake fluid. So after bleeding, I still have around half of the brake fluid left. I don't want to throw it away ($7.99 is expensive for me) and I cannot reuse the fluid because it is hygroscopic. What are the other uses ? What do you guys do with left over brake fluid ?
so if i buy brake fluid and is some left on the bottle were ever the brand is i have to throw it away? or you talking about the used fluid?
rodrigo
D
rodrigo
You can keep it so long as it's not hygroscopic. Bygroscopic brake fluid absorbs moisture which is bad, but if it's hygroscopic and you leave it's container tightly closed so no moisture can get in, you should be fine with it.
In the gun world, we have this stuff called Hoppe's 9. I use it to clean my barrels.
Guys love this stuff kind of like Honda guys love Honda Polish. It's not uncommon that guys use it as cologne for those very special occasions.... kind of like how Honda guys use Honda Polish.
For those less special occasions, maybe Honda DOT 4 brake fluid would suffice.
That, or dump it in the ocean the next time you go out to club baby seals.
How do you know if its hygro or bygro?
Put what you have left in 3 or 4 shotglasses and have a toast with your buddies!!!:all_cohol
Put some in your little brothers Goldfish bowl
That made me run to the garage to check the bottle, it didn't say.
I run Motul's RBF600 Factory Line DOT fo'
The website says "developed to resist high temps and wet weather conditions" so I would think it's hygroscopic yeah?
Seal the bottle as tight as you can and call it a day
I Love the smell of Hoppes 9 Rumple!! lol
Re: brake fluid. I allways do all 3 brakes if Im going to open a new bottle. Then when Im done, I squeeze the bottle while I put the cap on tight and then I use electrical tape to seal the cap. I also use RBF and that Chit aint cheap!
I've never tossed a can of opened brake fluid. Any DOT3 or higher brake fluid will want to absorb moisture from the air, which is why the bottles must remain tightly sealed. Not sure about others, but Motul RBF is sealed with nitrogen gas in the bottle instead of air to prevent the fluid from taking up moisture. As long as the bottle is very well sealed you should be fine.
1 - 17 of 17 Posts
