Well guys, it's been awhile since I posted and now I have another problem that I need help on.
When my push left for the left hand indicator, the left light on the odometer panel will go on, but it wont blink. When this happens, my left signal on my front fairing goes on, but it doesn't blink either. Additionally, my rear left signal does not even go on. (it's not integrated, it's stock)
Oddly, if I were to press my right turn signal (which is working) and IMMEDIATELY after press my left turn signal, then the left indicator blinks on both the front fairing and on the odometer panel. However, the rear still does not work.
I'm confused and I'm not good with electronics - can anybody throw me a bone here?
Check the rear turn signal's bulb its probably burnt
If it's not a burnt bulb sounds like you might have led signals and your stock flasher relay is confused with the power draw and not flashing... Get a flasher relay and hook it up.. T
He got stock signals
Missed that, Moe you hit it on the head, burnt bulb......
The IT rocks
