1 - 3 of 3 Posts
Bike: 2003 600rr
Lights: LED front flush front signal & TST IT
Problem: My tail light lights up but when i press the switch in the front and back. It won't go brighter. Also my turn signals don't work. But while i was in a middle of a ride it worked once and never again.
Any spots, relays or fuses i should check?
Thanks
Hi, do you have a LED flasher relay or our resistors wired in for your turn signals? As for the running/brake function would you be able to provide me with a picture of your taillight plug?
No LED flasher relay and no resistors. Before they were all working. Fast flash rate on the signals. I will get a photo later today.
1 - 3 of 3 Posts
